radardoug
The 400 volts, mentioned previously, is a RED FLAG CLUE!!!! With a 100 V rms secondary, you should not be able to generate 400 volts. All the clues point to a coupling between the two motor amplifiers.
I definitely am...Emil, you are fighting too many battles at once.
I'm reading 400VDC to circuit ground, as the incoming 100VAC is rectified and the presented at the collector. So I basically measure collector to circuit ground.Reading 400V against what reference? To circuit ground or AC 0V?
Yes, but I also don't see any voltage on any pins of the that plug in to the motor. I've measured all four of them in every possible configuration but it's as if the motor has to be connected in order for voltage to be present there (?!)The reason why the bulbs did not turn on, I have never tried it before but (even at transistors full turn on) is 100V sufficient to glow a 220V bulb.?
Yes, this is perplexing and it's even more strange that the 450 VDC stays at 450 when any mode is engaged. I'm going to start with removing the motors from the circuit and move on from there.The 400 volts, mentioned previously, is a RED FLAG CLUE!!!! With a 100 V rms secondary, you should not be able to generate 400 volts. All the clues point to a coupling between the two motor amplifiers.
I definitely am...
The only pin relevant on that plug is the one the motor is connected to. You are also measuring AC at this point with reference to AC0V. So, are you saying that when the transistor is on you are not reading 100VAC? However, again we will see that with the dummy loads. Under normal operation you should be able to read 100V across the resistor.Yes, but I also don't see any voltage on any pins of the that plug in to the motor. I've measured all four of them in every possible configuration but it's as if the motor has to be connected in order for voltage to be present there (?!)
Than you too.Thanks for the advice. I will get some heavy duty resistors and remove the motors from the circuit.
Mr Murphy is at work.What sort of values are we looking to find for dummy loads? I have a bunch of largeish Rs lying around I could contribute.
This thread is very entertaining, like a true whodunnit murder mystery!
