BC
470uf 25V 455uf, 9% DA, 0.0 ohms ESR
470uf 25V 453uf, 13% DA, 0.0 ohms ESR
Sprague
470uf 50V 473uf, 3% DA, 0.0 ohms ESR
470uf 50V 474uf, 3% DA, 0.0 ohms ESR
BC
47uf 63V 43.1uf, 4% DA, .58 ohms ESR
47uf 63V 42.4uf, 4% DA, .57 ohms ESR
pan HNG
47uf 100V 48.6uf 3% DA, .21 ohms ESR
New caps,measured with a Sencore LC102 within ten minutes, caps were formed the day before at working voltage, leakage readings were good.
maybe this shows why some like BCs? When you get to higher cap values the ESR does not seem to be as important because it becomes low
look at the DA
Sprague
BC
pan HNG
look at the DA
