I'm having some issues with my mic preamp. To start from the beginning :
My xlr input is setup as
Pin 1: Ground
Pin 2: Hot
Pin 3: Cold
My xlr is then connected to a electronically balanced input. I'm using a JR 12904 as the op amp. Pin 1 is the output, my hot feeds pin 3,cold to pin 2, pin 4 is grounded and pin 8 is my 18v+ supply. Pins 5, 6 and 7 are not used. My input looks like (https://www.google.com/search?q=op+amp+balanced+input&prmd=isvn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwickrev5e7PAhVKQyYKHdKABtUQ_AUICCgB&biw=320&bih=440#imgrc=Z5GfC-fJJcc7lM%3A)
The output of the balanced input then passes through a WIMA film cap, and then enters my preamp stage. (http://darrenyates.com.au/electronics/archives/16)
I used 3.3k resistors instead 2.2k, I used 100k instead of 150k. I used 47uf, 63v electro instead of 22uf. I used a 1000uf 25v electro for one 470uf and a 22uf, 50v electro for the other. My power supply is a 18v+ supply.
I then got rid of the 470uf output cap, and fed the base of a npn with the output. Fed my 18v+ supply to it and I used a 47uf, 63v cap feeding a 1k resistor (cap into resistor, resistor to ground) for my output. As Ian had instructed me for an unbalanced out. My 1/4 connector has pin 1 going to ground and pin 3 is hot.
Here is a couple pictures of my breadboard for help.
Input (https://postimg.org/image/3x5mho94t/)
Preamp stage (https://postimg.org/image/5wk7gulwd/)
Output (https://postimg.org/image/4n0y5clqb/)
https://postimg.org/image/bg0nvyrxv/dbd42ba8/
Transistor 1 is BC547, transistor 2 is BC547 and transistor 3 is BC557. The first BC547 is connected to the BC557 and the BC557 is connected to the 2nd BC547 for the output stage.
Can someone help please?
Pin 1: Ground
Pin 2: Hot
Pin 3: Cold
