My G9 is finished and functioning -- thank you Jakob for a well designed and documented project.
Here are some pics:
top view
http://www.photo.net/photodb/photo?photo_id=3538827
front view
http://www.photo.net/photodb/photo?photo_id=3538803
I thought I should share my experience with two of the more common G9 problems: 1) the oscillation problem at the highest gain positions; and 2) the low frequency hum problem.
THE OSCILLATION PROBLEM
When I first got the G9 working, the oscillation occurred in channel 2 at the two highest gain positions: at gain level 10 but only with the output control hard clockwise, and at gain level 11 at all points of the output control. Channel 1 was not as bad as channel 2, with the problem only occurring at gain level 12. The problem was worst at the 48v position, less so at the Mic position, and non existent at the Line position (with a guitar plugged into the front line jack).
During this first test, the G9 was connected (single ended) downstream to a Lexicon MPX110 sound processor (for monitoring through its headphone jack), and I could cause the oscillation to start by slightly increasing either the output control of the G9 or the input pot of the Lexicon.
What does the oscillation sound like? Well, first of all, no input signal comes through -- it just seems to be blocked out. What does come through is a whistling sound, sort of like tuning a shortwave radio, with very slight changes in the output level causing the whistles to shift. The amplitude stays the same, unaffected by the position of the gain level or output level.
This problem appears to be solved by reducing the load on the output. This is based on subsequent testing with other downstream devices as shown below:
- single ended output to Lexicon MPX110 (500K input impedance) -- oscillation occurs as described above
- single ended output to Peavey Bandit guitar amp (250K input) -- no oscillation!
- single ended output to Peavey Bandit guitar amp (44K input) - no oscillation!
- single ended output to Peavey Bandit guitar amp (22K input) - low hum problem, but no oscillation
I have not tested the G9 with a balanced downstream load.
THE HUM PROBLEM
The problem here was a heavy hum coming through the right channel. Touching the (insulated!) output wires or control board wires causes the hum to increase.
The solution to the hum problem included the following remedies:
- lowering (against the board/chassis as far a possible) the routing of the leads from output connectors K3/K103 to the output XLRs
- lowering (toward the bottom of the chassis as far as possible) the 10 pin and 5 pin leads going from the main board to the control boards
- changing the power supply caps (C14, C15) from 100uF to 200uF (as was suggested in a previous G9 post)
On my unit I have all the power supply leads running up over the board then down to their points of connection, and all the signal wires running down low as close to the board as possible. When I arch the signal wires over the top of the board I definitely get excessive hum.
I hope the above helps future builders of this fine unit. The beautiful nuances in guitar tone that my G9 achieves is remarkable.
Steve L.
