Some Newbie Questions... SSL?... Matchless?...
rmccam
Toronto, Canada
Hi Everyone,
I am new here... as of about 15 minutes ago, actually. First, congrats on a great forum - there's tons of amazing info here.
I am relatively new to the DIY thing, with the exception of the basic know-how of being an audio engineer (ie. soldering cables), but I'm looking at doing some small projects to work towards building an SSL clone and a Matchless clone.
- What are some good beginner projects?
- How difficult is it to build an SSL clone and/or a guitar amp? Are these really advanced projects or is it reasonable to shoot to try them out in the relatively near future?
- Any idea of approximate costs to build an SSL clone and/or a Matchless clone?
Thanks so much in advance!!
Ryan
Where do you live? (add your location in your profile)... I think the cost of certain projects will go up or down depending. In the states, I build SSL clones for $250-$300, depending on meter choice and panel art.
[quote author="Greg"]Where do you live? (add your location in your profile)... I think the cost of certain projects will go up or down depending. In the states, I build SSL clones for $250-$300, depending on meter choice and panel art.[/quote]
I updated my profile...
But in answer to your question - Toronto, Canada. However, I am fluent in the US dollar! :grin:
Thanks for the quick response!
Ryan
I don't think you'll find much info on Matchless amps here. You might want to try www.18watt.com or www.ax84.com
The cost for building a Matchless depends on which one you want to build, and what all you want to include.
The Matchless Spitfire is relatively simple: Maybe $250 for an amp excluding any enclosure or speaker cabinet.
The more complicated amps will increase in cost with the addition of things like a choke, more tubes, etc.
If you want to get fancy with faceplates, speaker grill coth, tolex, good cabinets, nice speaker, etc. you can run into the $800 range pretty easily.
DIY stompboxes make good first projects as they are not too expensive, can be completed fairly quickly, and are good practice for your pc-board soldering skills. Check out www.generalguitargadgets.com for some pre-made pc-boards. Also, smallbear electronics has lots of parts especially for making stompboxes.
