andybaker28
- Joined
- Jun 30, 2014
- Messages
- 87
I would love to have 3 or 4 Josephson e22s, but would be curious if there would be a way to DIY something even close?
Pip said:Small diaphragm condensers are a little harder to source then there larger siblings. But you could build one for sure. Getting the sound quality of a Josephson designed and built mic not as easy! Also the side address factor cardioid issue is part of the design problem of course.
You can buy capsules from SE and RODE fairly easily at most online retailers. But all of there product is designed for end address designs.
andybaker28 said:I would love to have 3 or 4 Josephson e22s, but would be curious if there would be a way to DIY something even close?
Tim Campbell said:Use a KM84 circuit, buy a sdc and turn it on it's side. The delay network is set at the capsule and should work as it is.
