skipwave
Roddy, I have one paired with the Royer 5840 cathode follower circuit that sounds great to me. I think they need lower bias voltage than is considered acceptable by some.
Rossi said:Are you guys talking about Chinese capsules in general or about these particular SE ones.
Rossi said:Zebra, the off-center gold circle may look disturbing, but it shouldn't change the sound at all. What I didn't like so much about the TLM49 is that I got the impression that they use a fixed low cut in the circuit. It certainly sounded nothing like my (K47 equiped) U47.
zebra50 said:Yeah, I know it won't make a difference, but it surprised me and made me wonder if Neumann use 'class b' capsules in their lower end mics. That's idle speculation on my behalf, and would probably have me kicked off less tolerant forums (fora!). Actually I know it's not a fashionable opinion but I find the TLM49 to be a useful mic - clean, very quiet, maybe a tad boring, but often that's what you need. It is sold as 'optimised for vocals' so your low cut theory could be right.
Gus said:I have a number of MXL microphones that have the 32mm capsule. Many have new or changed circuits inside them solid state and tube and combinations. One circuit that sounds good(to my ears) with a MXL32mm it is +140VDC B+, 100K plate resistor, 1K cathode resistor bypassed with a good 470uf cap, 1 gig grid to ground, capsule direct to grid, 60VDC charge voltage, MXL 32mm, 5840 tube wired as a triode, 5.7VDC heater, 1 uf cap to jensen DB like the Royer 2001, in a MXL2001 body, different clean power supply I built.
It is a lot like the Royer 2001 circuit. I like it with the grid to ground resistor instead of no resistor like the Royer.
Other circuits help or hurt the 32mm. I have built a lot of microphone circuits and tested changes to the circuits stock and changed. You can work with the 32mm but you need to try different circuits and transformers.
