Hello,
i am experiencing a noise issue at low frequencies something like ocean noise. I am tring to first troubleshoot the power supply by changing some capacitors and hear if anything changes. I've change tubes but the noise is exactly the same. i was trying to measure the very big cap (10000uF 35V) after a half an hour turned on with multimeter and the cap off the curcuit and i couldn't measure anything but a few nF. It seems that the capacitor is dead. With the ps turned on i measured the Volts and they are ok except the 142V at the C103-C104&C105 that is 8 Volts lower(around 133V-135V). is there any point to change all the capacitors? or start from the 10000uF one? The most important question is that the capacitor is a three pin capacitor and at the schem is C102 10000uF 35V x2. can i use a single two pin capacitor 10000uF? or it is a dual capacitor and i have to use two? i can't find anything with the service code from the Sony manual.
