dale116dot7
I just bought a Soundcraft 2400 and it needs a bit of help. The patchbay is a bit flakey, the faders a bit scratchy, and the switches are also a bit scratchy. Not terrible, but noticeable.
I've fiddled with mics and preamps and compressors, but never really have gone through a console like this before. It's not really overwhelming but....
The faders are no problem. P+G faders clean up really nicely and then they're quiet. The patchbay is more of an issue. Many of the cards have been re-wired with wire-wrap wire where the connectors solder onto the board. The board is single-sided so there's not so much support for the connectors that way.
Other than totally replacing the patchbay (and please, no debate on longframe vs. TT) I was looking at etching new patchbay boards and moving the existing connectors (which are actually still quiet and work well) to the new PC boards. The thing here is that if I am going to do that, should I look at putting the proper balanced I/O on this board? The whole board's I/O is unbalanced and I'm not too crazy about that. Should I glue down the jacks to the board so they put less stress on the solder joints?
I've tried different op-amps in one of the channels and it sure makes a difference - mostly to noise. The LM833 seems to work quite well in place of the TL072's but I do need to look at some of the circuit details before going any further on that. I would guess at least a 6 to 10 dB drop in noise on that channel. I know about the power supply issue - I have two of them.
I gotta say that things seem to gel better with this board than my previous unit (Tascam DM24). I know in theory digital summing is perfect but this sounds quite a bit better to my ears, even though there is more hiss and probably a bit more distortion. The bass, especially, seems to sit better in the mix, even without the radical EQ I was having to do on the Tascam.
Not a specific question but any comments out there?
