Chrome Heart
Im interested to know if anyone has a diagram of the input transamp mod/conversion that Jim Williams does on the 200B fixed EQ module.
TIA
TIA
I have seen a discussion of that mod, perhaps on geekslutz forum. As i recall it was reconfiguring the opamps and NF paths in the mic preamp so the preamp transistors are held constant current by the opamps (just like TA, AKA Cohen topology).Chrome Heart said:Im interested to know if anyone has a diagram of the input transamp mod/conversion that Jim Williams does on the 200B fixed EQ module.
TIA
living sounds said:I've started a number of threads here and got very helpfull advice regarding modifications of the 200b. I ended up with significant changes, resulting in superior performance. Using the line ins there is no cap in the signal path (except the one in the DC servo), very little noise, distortion and the EQs sound great.
Modifications include the ground mod mentioned before, changing grounding to have a seperate signal ground and a power ground, changing the input circuit around the servo, upgrading many parts to higher quality, modifying the EQ range, upgrading the PSU, using better op amps in most places, adding PSU bypass caps.
It's been A LOT of work, and looks rather messy, but worth in in terms of sound, which is now very clear, transparent, balanced, punchy,.... uncoloured, but it sounds much better than what I could ever get ITB.
TIA
