rod gervais
[quote author="Svart"]So far, nothing but drywall. This was a test fit. The drywall buts directly against the door frame with no gaps. This portion will be cut back about 1/4" and sealed with silicone. The hinges will be covered from the front to hide them[/quote]
Svart,
You need to reconsider this application.
Drywall had no strength in it - and there is going to be a lot of shear stress loaded up on those screws.
With a wood backing the stress is taken out as an actual shear of the screw - but with material like drywall it is taken out as a bending stress.
It takes very little to bend a screw - it takes hundreds of pounds of pressure to shear that same screw.
I can promise you that it will not be long with those doors in operation before they begin to sag from the weight of the door on the hinge.
BTW - just so you understand before even having to ask - the bottom hinges are douing very little to carry the door - the act more as a lock to stop the bottom of the door from sagging in - but they act as great hinges when it comes to the top of the door sagging out. So they do not solve the problem you're facing.
This is why I always recommend that people use 5/4 stock minimum for door jambs (that is 1 1/2" thick material) and that the hinges be fastened to the jamb with very long screws.
The hinges are then tied into the jamb AND the framing - everything is solid - and you can have as many layers of drywall as you wish without a care in the world about the door loading.
I hope this was clear so you understand.
Rod
Svart,
Rod
