Source for rare Cannon connector (for Akg N61)
Twist Turner
Chicago, Il
Ok, I've been searching all day and I give up. I need the 6 pin screw in male connector for an AKG N61 power supply. On the schematic the part is listed as RWK-6_22c-1/4. I had some luck searching wk -622c but still couldn't find any more than the part existed. Should be made by Cannon, but this could possibly be an Amphenol part as well.
Anybody got any ideas??? I thought I might just swap out the female connector on the unit but it's just too tight in there, the current connector actually juts out beyond the unit to fit.
On a better note. I also spent 1/2 a day looking for the Cannon connector for the power cord on my Collins 212Y mic pre which I have never powered up. I got lucky and found it to be an Amphenol part. The part number (available from Digikey in the US) is MS3106A-14S-5P-ND. So if anyone is looking that might save you about a day of searching.
I'm also looking for some RWK plugs. I don't mind if they are not 6-pin as I can get the inserts from elsewhere.
Please PM me if you have any.
Roddy
Roddy - can you shoot across a photo? I have a box of circular connectors and there is a small chance I have something.
PSW link doesn't work, but then again I am banned!
Thanks Stewart. Oddly, the cable is a "death cable" and is male at both ends. It has a threaded collar; the non-threaded version is just called an RK.
Here is a picture. It's the upper plug which I am looking for:
http://blag.proaudioeurope.com/dspImage.php?image=http://blag.proaudioeurope.com/assets/dynamic/51/images/gal/original/734_1363708696_akg-c12a-5.jpg
Death on a stick!
I will have a look in the box, but i have a feeling that the threads on these are different.
Roddy
Check this:
http://www.ebay.com/itm/Cannon-WK-6-22C-6-pin-male-for-Altec-tube-mics-Church-Cine-Mic-/141090668267?pt=US_Pro_Audio_Parts_Accessories&hash=item20d9a8beeb
SSLtech said:
Ooh./...C12-A connectors?
Yeah, I have a mic, but unable to connect it to its supply. Have now purchased a marian adapter from Telefunken USA. I have a C12, C12a and an early 414. You can never have enough brass CK12s.....
ln76d said:
Check this:
Thanks for spotting that. Apparently it won't work though, as it's the WK version which doesn't have the loose threaded section which the RWK has.
