Any experts in the house on this one? Im having some wierd stuff go on and could use some help if anyone has practical experience calibrating these. I dont have a schem for the 601 card, which is helping none. I have two cards and there are some different cap values on each. Since there is no silk screen on the cards, try to follow-
Looking at the board component side up with the edge connector on the left, what is the function of the cap second position in from the left in the row closest to you on the lower board (eck, follow that...)? One card I have is a 2u2 and the other is a .68u.
The problem Im having is that I can get the thing calibrated to see the first 3dB of gain reduction and the meter doesnt track the release at all. The card with the smaller cap in that position tracks a bit better but not by much. Followiing the cal procedure gets me nowhere, the unit isnt metering the first 3 dB of reduction at all.
Also on the 601 card, on the top daughter board, what is the value of the electrolytic on the lower right, 56u 6v?
If anyone has a factory schematic it would make this a whole lot easier to communicate...
dave
dave
