CJ
2004 WTF?
FredForssell said:The orginal 610 used Triad A-67J (or 65) input transformers and an HS-66 output transformer. While the HS-66 isn't too bad, the A-67/65J sucked big-time IMO. That could be part of the HPF sound someone mentioned earilier.
It also used a really nice API-361 VU meter (that cost a fortune) and the SS 101 card which used +24 VDC rail. That card was later replaced in other SS designs with the SS 110 card which used +/- 24 VDC rails. But if I remember correctly each of these cards had 604 ohm input impedances due to the fact that they used grounded base input stages. The single-ended power supply and low input impedance mean one needs to use large value caps for inter-stage coupling. That is not something that can change if you use the SS 101 or 110 cards, so I'd look at using something other the SS amplifiers.
Basically, if I were going to make a 610 clone, I wouldn't. I'd make it with the 601 and 603 cards (good meter tracking vs ratio setting), a good output/gain make-up amp (guess what I'd use), and better transformers on the input and output. And I'd try to DC couple it from input xformer to output xformer. But then again, I'd get rid of the input transformer and used a balanced to single-ended input stage. That's me.
I think it would be interesting to see what that sounded like. I actually liked the way the 610 worked but not how it sounded... so much. Because it has the ability to work at such high slope ratios (100:1, if I remember correctly) people tended to have trouble setting it up properly. Typically they ended up saying it "pumped" too much. Go figure.
Do you still have the schematics for this unit? The links before your posting are now dead and go nowhere. I would be interested in receiving -- any and all -- Spectra-Sonics schematics that you might have. I have more than enough capable CAD-design software to take your old schematics and create all-new CAD-schematics and PCB-layouts!!! That's what I do!!! Let me know, OK??? THANKS.Given the amount of circuitry involved (not a tiny amount by any means, but feasible to put on one board) I have been thinking about thinking about making a clone. Has anyone done this before?
Thanks for the schematics Ed
drew
www.toothpastefordinner.com
Would love for someone to recreate those cards. The schematics are here: https://groupdiy.com/threads/spectrasonics.45521/#post-570251Do you still have the schematics for this unit? The links before your posting are now dead and go nowhere. I would be interested in receiving -- any and all -- Spectra-Sonics schematics that you might have. I have more than enough capable CAD-design software to take your old schematics and create all-new CAD-schematics and PCB-layouts!!! That's what I do!!! Let me know, OK??? THANKS.
THANKS!!! -- I already have downloaded all of those schematics into a separate "Spectra-Sonics" folder on my hard-drive. Now.....do you or anyone have any -- detailed -- mechanical data and/or dimensions of the original cards? That would help immensely.Would love for someone to recreate those cards. The schematics are here: https://groupdiy.com/threads/spectrasonics.45521/#post-570251
No sorry. There are some clear pics of the original cards here, but of course you can only see the routing of the bottom card, not the top one.THANKS!!! -- I already have downloaded all of those schematics into a separate "Spectra-Sonics" folder on my hard-drive. Now.....do you or anyone have any -- detailed -- mechanical data and/or dimensions of the original cards? That would help immensely.
For me personally, I would probably design a whole new and different type of PCB to fit within a 1U rack-chassis. But, if someone wanted an exact clone of the original PCBs, then I would need either highly-detailed mechanical dimensions or someone would need to physically mail me an actual Spectra-Sonics PCB so I could "Reverse-Engineer" it. As an example, a few years ago some guy down in Florida had bought an original 1974 API mixing-console that he wanted to restore and he had mailed to me one each of the PCBs that were inside. He wanted me to exactly "Reverse-Engineer" the original PCBs so he could then have fabricated exact "New/Old" PCBs for his API mixing-console restoration project. And, even though I could have made some easy routing improvements about the layout, he wanted the PCB routing to exactly mimic all of the originals. I get it. Anyone? Bueller? Bueller???
[which free pcb software and which pcb service do you recommend taking in to account that I'm from europe] -- KiCAD 6.0 is all the rage these days and it is a European-based -- FREE -- PCB design software program. You can download it from here:Just let us start to recreate a pcb, You can also suggest to replace the front discrete amp with an opamp, lunchbox and so on.
But with the info we have we can try to copy the idea esp. of the gainreduction and than later see how we are going to implement it. I'm willing to help on this. What we need is:
-which free pcb software and which pcb service do you recommend taking in to account that I'm from europe. I've done a bunch of pcb's in the past or if somebody is willing to do the work I'm willing to check it or help where I'm needed.
-Who is willing to do a Spice model? Something we are gonna need for shure. I can do that, but I've never done that before. I will need somebody who wants to look over my shoulders.
-Who has a physical unit (preferable a later adission) and is willing to make pictures, make audiofiles,...?
Got it!!! ..... THANKS!!! Now.....would you happen to have any mechanical detail drawings or specifications of the dimensions of the PCB, the location of the edge-fingers or any manner of mechanical dimension details? That would certainly help out immensely!!!Found this as well
