OK, one question. The flip button - I presume it is latching or a toggle i.e it has two positions, normal and flip.moamps said:Yes.![]()
OK so the schmitt debounces the push button and clocks the D-type which is wired to divide by two so it simply toggles on each button press so the channel flips to the opposite state to what is was. R104/C2 ensure all D-types are reset at power up. Otherwise state is set by global S or R.moamps said:It is a momentary push button. The logic circuit behind is on the picture.
The global switch can be single (with a small logic circuit which I can draw tomorrow) or just two momentary switches which provide power voltage via small resistors to two control buses.
Was afraid you would ask that. :-\So where in these paths does the EQ appear?
No, not at present. Line in is going directly to A1 or Slot 2 for now. Input TX's are only on Slot 1 pre's.Do you have an input transformer as well? I seem to remember API uses input transformers as well as output.
Nice instructive toggle circuit, thanks for postingmoamps: It is a momentary push button. The logic circuit behind is on the picture.
Matt C said:Ian, I modified my console to have an arrangement similar to (but very simplified) what you describe. Mine just uses a two position toggle switch.
In one position, the direct out is fed from the mic preamp, and the tape return is fed to the EQ and then the channel fader.
In the other position the direct out comes from the output of the EQ, and the tape return is sent straight to the channel fader.
This way the faders are always controlling the tape return and there's little/no changeover between tracking and mixing. I love working this way and to me it makes the other common mixer architectures look insanely cumbersome. The only awkward part of my setup is that it doesn't have your center "normal" position, so to get the mic preamp signal to go directly through the channel fader and into the groups, you need to patch it through the patchbay. But I rarely do that so no big deal for me.
Yes, basically the recorder is permanently in the insert loop. Not a practical solution for a mixer being sold to the general public, but for my own personal use it's great. I think I originally got the idea from Steve Albini/Electrical Audio. They have a modified Neotek console that's setup up in a similar way to what we're talking about.ruffrecords said:That is an interesting way of working. I guess you rely on the tape return being fed from the tape in when the track is in record?
pvision said:Global status switch plus a local channel status invert switch. If you make the latter non-latching you could have a master reset so you don't have to go looking for inverted channels when resetting the board
Nick Froome
I cannot find the picture but I think Helios had this 'pegged' back in the 70s. They used a kind of mini peg board with inputs on one axis and outputs on the other. You just inserted a peg where the output you wanted met the input you wanted it to go to. Very visual, reasonably intuitive and no trailing patch cords.PRR said:> *everything* being manually patch-able.
That requires "a brain", which may be in short supply, especially after 13 hour days all week.
Also a darn LOT of jacks. Which are not cheap!
It really gets to the point that we want "everything to everything" routing, and an AI to listen to the mix-operator and figure out the connections.
There's one thing I wonder about when implementing a design like this. I see a big opportunity for creating feedback loops using the buses. If we group a couple tracks through a bus and send it to a track on tape, then it gets returned to a separate fader, does anything prevent that tape return signal from being routed to the same source bus, making a feedback loop? Are the buses somehow kept separate in a way I'm not seeing? The way I configured my console I just have to be careful, but I very rarely use buses to group tracks to tape so it's not a big issue for me.Brian Roth said:2. A rotary level pot adjusted the level from the internal mic pre (or line input) and was routed to the multitrack buses. A variant that I did when I built a 24 track desk (back in the 1970's) was to have a "Direct" switch which selected the channel signal vs. the bus feed.
Matt C said:There's one thing I wonder about when implementing a design like this. I see a big opportunity for creating feedback loops using the buses. If we group a couple tracks through a bus and send it to a track on tape, then it gets returned to a separate fader, does anything prevent that tape return signal from being routed to the same source bus, making a feedback loop? Are the buses somehow kept separate in a way I'm not seeing? The way I configured my console I just have to be careful, but I very rarely use buses to group tracks to tape so it's not a big issue for me.
zamproject said:Hello Ian and all
I think we already discuss this before for your tube console signal flow
I'm certainly biased (Studer addict) but the remix function is a nice feature for a small mixer.
Best
Zam
