I'm glad to hear you are back to looking at the MAX7400 chip.
I should mention that EPROMS, counters and other support chips are overkill.
A cheap and fast modern microprocessor, 8 bit or 16 bit, can easily generate MULTIPLE clocks and "tone" squarewaves that the 7400's require.
Just a rough guess, I'd say one microprocessor can generate 4 or more pairs of clocks and "tone" squarewaves on the output pins.
The processor is much more flexible than hardware and you could generate special effects through the programming of the micro.
Now that I think of it, cutting the signal to the input of the MAX7400, will cause this type of 8th order filter to "ring". You can get an automatic decay of the tone. I'm not sure how practical this is however.
Now the bad news. The MAX7400s are a bit expensive and distributors are often out of stock.
In any case, I'll be following this thread to see what you come up with.
Very interesting project.
