SSL 4000 E series Console, Restoration and Chop down Project
S
sintech
Guest
Hi, this is the latest project on the bench ;-) The plan is to chop the console down from 40, to a super cute 24 channels, also removing the G+ computer.
If anyone has the schematics for the Plasma metering, I would be in your debt :) I've only dealt with 4k's with VU metering in the past, so this is a new area.
Any suggestions are welcome :)
SSL arrives!!
Frame In and ready for reduction on Monday
PSU Fired up, first time in 6 months.. fans sound nice and quiet :)
Bypassing the computer, via the Fader buss cards
Bypassing the computer, VCA 1-8 and Master Fader In Blue
Most cards look great, and a lot have been re-capped, this is the worst!!!
ouch!
sorted! :)
40 channels? That may very well be our old friend from Feedback Studio 2 !?
I may still have copies of some of the documentation - let me know if you miss some..
Jakob E.
Jakob E.
Aha!!! Jakob, the console came from Denmark,... so it just might be :)))
Any info, would be great, thank you. I didn't get a service manual, found some stuff online and within the forum. There was stuff in the GroupDIY Gmail, but I think a lot of stuff has been deleted from that account :(
When you chop it down from 40 to 24 channels, do you have any channelstrips ready for sale?
Just asking, because a friend of mine would need 3 channels from a 4k board.
Are you re-capping the VCA cards? I've been doing a re-cap on a 4k for the last week, and noticed an error on the silkscreen on the VCA cards...it shows a + where the negative leg of one cap should go. I believe it was C11 which is a 22uF cap.
Good luck!!!
That's a great project.
Go through that PSU and check all mechanical connections- the screws on the caps/bridge rectifiers, the lugs and the euro barrier strips.  Any sign of heating of the crimp connections is a warning that should be heeded.  A 40 frame load is not so bad for one supply, but check it through.  I always clean the lugs and the screw terminals with alcohol and put a light wipe of progold on them.  Anything brown or even worse, green gets cut and re-lugged.  The caps go as well if they are original.  Same with the 1000 mF axials at the output of each voltage.  They are hidden in the rats nest of wire at the back and forgotten.  Clean the edge connectors and PCB's of the regulator cards with alcohol wipes on cardboard or plastic card stock, and apply a bit of progold.  I also find that those transformers on the cards like to get cold solder joints over the decades, so give the boards a good look.
The thing will last forever powering only a 24 frame.
Mike
When going through the supply, check the colouring of the wires, i've had a cap (i think from the +250V section) go bang-- the colour coding didn't match what the schematic said-- + and - off of the bridge were black/yellow, but were the wrong way round! So i followed the schematic, and hooked the cap up the wrong way... doh!
Hmm - off the top of my head:
- One of the sides of the back-bus (the two last of the quad bus) outputs was phase reversed - we never found the electronic reason for this. I don't remember if we changed it at the card or at the patch panel. So look out for mixbus phase reverse if you change the cards. EDIT: my notes, freely translated, say: Backbus R pre-VCA insert, cable "L4", has been phase-reversed - on purpose - at the connector "SL90" underneath the board - reason was unexplainable phase reverse on BBR. 22-02-1998
- From time to time the 4040 develops some very confusing crosstalk between aux sends - this is due to damaged switching FET's (in center section iirc.). Very hard to diagnose properly.
- Be VERY careful when servicing the plasma meter driver electronics - there's +250V in there, which hangs around for a long time after power down.
Note:
I found quite a lot of left-back original documentation when I looked through our storage room: Maybe we could make a deal: I send you everything that I have, and you promise to get it scanned and posted online (possibly in this forum?) for others to use? Reason is that I simply don't have any spare time for this sort of stuff right now, and I'd rather not part with it unless it can be made publicly accessible.
Jakob E.
gyraf said:
Note:
Jakob E.
Jakob, that would be brilliant, I have a great scanner here, shall I PM you my Address?
Thank you to everyone for all the suggestions and advice, it's all massively helpful  8)
Todays Progress:
mornin'
My mate Si starts to adjust the Metalwork
Finished, the 24 frame :)
De-looming the two end buckets
The Split
The 4024, super compact
Console and frame ready to move inside this week.
The stuff left over
Checking for fit, the 16 bucket on the 24 frame
gyraf said:
If possible, please make sure that Ptownkid gets the info he needs....
Jakob E.
Indeed, please do!!! I've seen some discrepancies in different versions of the documentation so it's always nice to reference other sets. In the meantime, if you need anything specific just ask Sintech.
Awesome! Guys, you rock!
I have an access to grey fat books, plasma schemo is here, as well as some other stuff.
The book which have plasma schemo is always at my workshop, can scan or take hires pic.
Feel free to contact, mail/facebook/skype.
(edit: is this the info you need - check the photo?)
    234.3 KB
Thanks Igor, that's the section I need :) if you have the time, it would be awesome :)
