SSL 4000 E series Console, Restoration and Chop down Project
Awesome project and great photos!
Please treat your mate Si to a pair of goggles to match his ear defenders and angle grinder! Those things scare the crap out of me.
8).
Todays progress: Back as a 4024 :)
On the bottom of the 651, I have homes for all the connectors and ribbons, apart from one marked: S93E any ideas guy's?  8)
In my old manual, S93E is listed as...
82E113 Floppy Disk Front Panel
82E114 Floppy Disk Rear Panel
Pin No    Description
1            Left Unit "R"
2            Right Unit "R"
3            +24 Volt Return
4            +24 Volts
5            +5 Volts Return
6            +5 Volts Return
7            Run Lamp II
8            Run Lamp I
9            System Reset
10          Not Used
Don't think your setup will need it.
1st suggestion, get rid of the plasma meters & put in VUs. The plasma meters inject noise into the mix buss, and are expensive & a PIA to keep working. It is exciting when they smoke, though ::)
Why did you solder links to bypass the computer? All you need to do is plug in jumpers, then it can easily be reverted if ever required. I would suggest reversing this change.
If there is a TR computer (a 2 card sub computer in the main frame) I have a client in desperate need of one...
Well, mail did'nt passed (maybe due to file size), the schems will be here for about a month, feel free to download:
http://ij-audio.com/downloads/ssl_bargraph_metering_sys.rar
More bad caps, but it's a breeze to change caps being so modular :)
Wiring one of the spare buckets :)
Allen&Heath switch mode console supply feeding the bucket +/- 18v , an extra 7v power supply is tied to the +18v subtracting, to give +11v on it's common, making the logic Hi (+18v) and logic low (+11v) states
Power!!!
You will notice the the resistor next to the burnt cap in your photo is toast, looks like the fusing resistor. This means there is a short on the card, probably not the burnt looking cap...
Any more updates Sintech? You finished now?
This project is something I've considered for a while now and your report is simultaneously encouraging and off-putting!
Hi, yeah, it's all done, here's some more pic's of how it all looked in the end.
Light portable stand
D-subs
More Recapping
Power up test
Master Status
4002E!!
First 8 bucket done
Self Etch  Cue Amp card
The 24
Second Bucket
