Ptownkid
Do it! I dare ya!
signalflow said:Prototypes came in. It'll probably be mid January to beginning of February before I have one up and running due to the holidays and the never ending spirit of Christmas that is my wallet.
http://www.groupdiy.com/gallery/0/11898-081211095718.jpeg
-Casey
signalflow said:
1) Relay's are popping when switching in the bypass. Could be the switch I'm not sure, but in case it's not what could be causing this? I have caps and diodes on the rails going to both relay's but still have the pop. Any thoughts? I used the same relay setup that's in the SB4000 and i haven't heard anyone having problems with it.
2) When switching into bypass I lose about 5-6db of signal. even when the eq is flat this is happening. Kinda puzzling to me.
wolfgang said:And for the Level Drop: I havent looked if you need 6dB Gain after your EQ- Circuit????? Input is THAT 1240 which is unity-Gain and output is THAT1646 which has 6dB Gain. May this is the answer??
regards,
Wolfgang
abechap024 said:I think, this would be a fun project to build!
