MartyMart
http://www.pbase.com/martymart/se5a_buildssl9k&page=2
Two pages of gear porn, click on the link and any photo then use the "previous/next" icons to scroll through ( SE5A valve amp here also )
Well, it's my first real "Pro Rack" build other than a couple of amps and various stomp boxes and I'm VERY pleased with it indeed
Build :
Bought boards and parts for 4x 9k's but decided to just do two to start with.
The rack was an old Peavey system processor, a bit scuffed up but the front panel was reversible.
All boards fitted out took 1&1/2 days and a further 2&1/2 days to drill out the rack and fit/ wire all the sections.
I took my time, which thankfully resulted in a working unit on first power-up ! :green:
Keith helped me with my only issue, overheating regulators which was solved with some insulator kits.
Parts were sourced from Farnell and Rapid plus several things that I had here, such as caps/resistors/nuts&bolts etc.
PS is an 18-0 18-0 AC 30Va toroid, primary of dual 115-0 v AC
Working substitutions :
Went for some TLE 2082's instead of the TL052's but used 1N4148 diode pairs from the +18v and -18v rails which gave
me approx +/- 16.7v for this chip ( rated at +/- 19v max )
Used LM394's for the MAT-02 packages, which are pin for pin compatible.
Pots were Audio maintenance dual reverse 2k2's, which are fine but have a small 4mm shaft ( gain knob connection )
JLM Audio go-betweens used for phase/pad/48v connections, Di's also ordered but wouldn't fit this racks front panel, as
it was 3mm steel powder coated - just a hair too thick !!
Several resistor "subs" which included 47k's for 50's and slightly lower values to the gain pots ( 33 ohms and 22 ohms IIRC )
Mixture of metal film & carbon film resistors used and caps were Wima/AVX/MKT and ceramic for all values in pf apart from
2x silva mica 330pf's
Outputs pre- balancing board go to jack sockets for easy monitoring and the balanced outs go direct to my Fireface 800 DAW.
I couldn't detect any issues with this when both are connected ?
Sound / Performance :
Sounds great to me, a BIG and warm tone, I wouldn't say "neutral" as it has a sound of it's own.
Good bottom end and nice sparkly high end too - VERY pleased with it and it's quiet as a mouse, star ground used so it's
totally "Hiss/Hum" free .
Rack labeling :
Yes, I know it's a bit "Heath Robinson" meets "Pete Cornish" but it works for me and turning it up means that it gets LOUDER !!!
Injuries :
One small cut to left index finger and one soldering iron burn to left thumb !
Cost :
Old rack - Free
Ordered parts for 4x units £220
Other stuff I had/scavenged £25
Total £245 ( Under $500 )
Total for 2x 9k's £130 ( Under $270 )
Thanks go to the following :
"Keef" - SSLTech for the original schems and constant good natured help
"Gustav" - for the superb and trouble free board sets
"Aron Nelson" - for getting me into this stuff in the first place in 2003
Everyone else here who's answered my questions and posted such useful stuff in the Meta etc.
Build :
Rack labeling :
Injuries :
Cost :
Old rack - Free
