SSL 9K hissssss...
Neeno
Switzerland
Hi ppl !
I've solved most of the noise problems mounting my 4 ssl preamps inside a rack unit, i've connected them with star ground and i've also changed the transformer for a toroid 20-0-20 and now they sounds clean and noise free... :grin:
Now i have a hiss problem, only when nothing is connected to the mic input. The hiss is terrible loud...
Anyone can help ?
Neeeeeeeeeeeeeeno
[quote author="Svart"]does the hiss change when you turn the gain up/down?[/quote]
yes... it changes if i turn the gain control...
do you know ho to solve this issue ?
Try a 1K resistor from 2 to 3 and see if the noise drops.
Transistors can become hiss generators if the junctions get "hurt"
I've placed a 2k2 resistor between pin2 and pin3 on the input xlr connector. And i solved the input hiss problem, but now i have almost the same problem when i power off the unit... no hiss but hum, it seems a ground problem, even if all the boards are grounded to the same point and i'm sure i don't have any ground loop inside the box...
any suggestion ?
Thanks a lot for your help guys !!
Neeeeeeeeeeeeno
phantom on or off? phantom on with power supply ripple can cause your hum. Check the supplies with a scope.
The original preamp in the console has a set of optional resistances that can be switched in between pins 2 and 3 to provide alternate impedances. Try a couple of resistors, like 1.5k, 560Ω and 200Ω.
Keith
Hello, I know this topic is old, but I finished my SSL9K, just one channel of 4 that I want to build, and I get a little sad with the noisefloor of it... there is a hissssss that become louder with the gain...
I'm using JLM Go Between + DI.
Connecting a Mic, I think the noisefloor is hugier than my Neve 1290 that's dead quiet... althrough I separarte the PSU from the main box (I have the psu outside) I connected the pins 1 to the ground as used to be. One guy told me that maybe there's a problem with the MAT02... maybe they are not propertly matched... humm.. too strange I think.
I need to test in my studio... but at first sight, didn't like it :(
That resistors across pin 1 and 3 can solve this hiss problem without interfering the gain? Is there any inconvenience doing that?
Any ideas and experiences?
Eddie  :-\
There can be a hundred reasons for hiss/hum/noise.  I didn't match my mat-02s and I don't have a hiss problem.  I wouldn't worry about that.
That resistor can affect gain.  I believe that you have a different problem here.
Can you tell us a little more about how you built the unit?
Hi! I tested yesterday in my studio, there's a slight humm (50Hz)... it's just a simple ground issue I can manage... about the hissss, it is there in extremely gain values... actualy at this time I don't know if is a real problem with something or if it it some SSL9k's characteristic. It sounds good, but a little bit muddy... I'll compare with a friend's one so I can tell the differences... I builded mine with JLM Go between plus Fet DI and substitute the pot for a 24 pos dual gang rotary switch (2x 2.5K log).
Work fine...
I'll compare and will post some photos!
Eddie  ;)
It's an old thread, but let's give it a try...
I finished my first ssl 9k preamp out of two and I have strange hiss behaviour. I have a short xlr female connector wired into the preamp for testing. When I connect the microphone directly there everything is ok, nice sound, not his at all. However, when I plugin a microphone cable the hiss rises a lot. Also, with a long cable (10 meters) I get distortion in the unit. Is like if the longer the cable, the higher the gain it is providing...
Also, I'm running everything +-17V for testing RN
I attach a picture.
    1.6 MB
So you have the board just sitting on the bench, no shielding? What do you expect? Put it in a shielding box before you make final judgements. Its a 60 dB gain preamp.
