scott2000
isn't shielding only a concern when we talk about hum?
Hum ,Buzz and Noise are all fair game
Test it with connected shields of the short cables for gain pot to the ground.bernatvm said:....When I connect the microphone directly there everything is ok, nice sound, not his at all. However, when I plugin a microphone cable the hiss rises a lot. Also, with a long cable (10 meters) I get distortion in the unit. ..
moamps said:Test it with connected shields of the short cables for gain pot to the ground.
Also try it with added small caps of 100-500pf from input pins to ground.
As I see, the short cables you are using for connecting potentiometer are shielded. Where is this shield connected?bernatvm said:I don't understand. Do you mean connecting the chasis of the potentiometer to the ground?
