[quote author="gyraf"]An approach for a (mono) sidechain insert could be:
Take the two "to sidechain" signals, and add them together with two 4K7 resistors.
This becomes your insert send.
Connect the two 47K's at the input of the sidechain together.
This becomes your insert return.
Use a tip/ring stereo jack socket. Send to ring and return to tip. Normalize ring to tip. This way you can also use the insert as an input (for ducking etc.), and if no jack is inserted it will just act as a normal clone.
Result: Insert point output impedance ~2K5, input impedance ~25K.
This should be good enough for most purposes.
Unless I missed something - I havent really slept enough the latest couple of days..
Jakob E.[/quote]
excuse my ignorance,but what are the two "to sidechain" signals?
are they located leftside from the distortiontrimmer when i look on the board?
if it is like this,do i have to cut before left or right side of the resistors?
