khstudio
I would guess the 9Ks can only be better.
Hopefully "Better" but probably just different.
That's the feeling I had about the FX series pres... Seemed like there were trafos in there, which I'm guessing there aren't... Anyway, good luck on yours.. BTW, one MAT02 measured weird, the other had both sides equal.. Im going to see what happens when I swap that bad MAT02...khstudio said:He also said they are "Clean... but not clean, BIG sounding & that they almost give you the "Sense" that there could be tranny's in there. He also mentioned having a "Color" or "Sound" to them... unlike what some others have said about them JUST being "Clean"...BTW, Kevin, did you get my PM about the night EQ?
Good luck man.
OK, that's obviously not the way to go.. I just broke another one... the pots (and everything else, is pretty mush loose in the air right now for lack of a case, so turning the pot has to be done very carefully, obviously to me now!I have them soldered to the pcb, and then soldered a wire from the resistor to the pot..
Page 2, 2nd.parameter. delta hfe is the difference between current gains of both transistors in this housing, indicating how close these match.mitsos said:I checked the datasheet but didn't see that info.. bad eyes I guess. Well, this sucks.. one $10 transistor in the trash.. I'm gonna go through the rest of the circuit and hopefully all will be ok in the end..
Thanks for the info...
mitsos said:I'll try the shielded cable... I had tried twisting cable til I read someone's suggestion to use straight wiring, as short as possible.
This spot is a little sensitive to induced garbage.
Hi Kevin,khstudio said:What kind of garbage? When you say "Induced" are you referring to inductance? or just "injected noise in general?
I do feel like this Pre is missing a little "High-End"... could these twisted wires cause that? I will try to run sweeps on it when these sessions are complete.
I had mine like this initially, but somewhere in my "extensive troubleshooting" I changed them. Will put them back like this to see if it helps.signalflow said:I Connected all my shields from my inputs to the input GND on the boards.
I have these floating for now, will try changing the inputs first and see if I can leave these like this.Then I connected all the shields for the output to my DB-25 output connector.
Here is another question.. I am using Keith's PSU(the one that comes with the pre boards), and it has a 0V for each output (they are all connections to the PSU ground plane)..I wonder if I should cut two of the wires and only leave one connection between PSU and star ground??The only "star ground" I have in mine is that all the 0V are connected to the 0V output of my JLM power supply.
Numerous times...mushy said:Have you tried rotating your toroid yet?
gltech said:Look at this schematic (rotate it so the text is oriented properly):
http://www.beatbazar.com/guests/ssltech/9k/9k-schem.pdf
The pots are oriented so that the wipers move up as the pots are rotated clockwise.
Here's another way to look at it:
