New guy here, trying to figure something out. I came across a schematic in a book I bought at the flea market the other day and I would like to play around with it. Very basic circuit, transistors, resistors, diodes and a couple of caps. Takes a + and - 6 volts. Since it's from the 60's, some of the part numbers are not coming up well with a google search. Here they are:
SG22 diode
2N541 transistor
2N478 transistor
I believe these were made by the Transitron company. I did find a .pdf of the data for these parts, but I don't think it's as easy as matching them up with modern day parts and dropping them in, but again, I'm really new to this. Quoting from the book, "Stabistor DC coupling eliminates the need for large bypass capacitors or excessive bleeder current. Stabistor coupling also fixes the collector-to-emitter voltages at a low value, about 1 volt. It goes on to say that the stabistor diodes prevents damage to the base-to-emitter junction by any excessive negative signal.
Here is the .pdf info that I found:
PWR. BV BV Hfe Ic Vce Vce Ib Ic Fr Icbo Vcb Icbo Vcb
Diss. cbo ceo min-max (sat) MA MA mc uA volts uA
mW volts volts volts 25C 150C
2N478 NPN 200 15 15 40 100 1 5 1.5 2.2 5 8 0.5 50 15 15 TO-5
2N541 NPN 200 15 15 80 200 1 6 1.5 2.2 5 10 0.5 50 15 __ TO-5
SG22:
Max Forward Voltage Forward Reverse Reverse Power
Volts Current Current Voltage Dissipation
MA uA 25C Volts mW
.47 min./.53 max. .25 .1 2 250
.52 min./.60 max. 1
.64 min./.72 max .10
.67 min./.77 max .20
.64+/-10%
1 100
Based off of this information, do you think there are modern replacements or is there not enough circuit information to determine.
I just started getting into the DIY stuff. Hope it's not to late to start learning. Thanks.
Tom
SG22 diode
2N541 transistor
2N478 transistor
SG22:
MA uA 25C Volts mW
.52 min./.60 max. 1
.64+/-10%
1 100
Tom
