Stancor Tranx wiring?
iomegaman
GDIY Supporter
Tucson, Az
Looking at using an older Stancor A-4352 in my tube pre (charlys redd47) but I cannot for the life of me find any wiring diagram...its the same a s a 4351 except the oHm's slightly different:
1:13.3
500/333/200/125/50
89k
The thing I am seeing is it has the secondary with six tabs no wires (1-6) and the primary as G-G with a CT...
Case is stamped Stancor and it has A-4352 on the windings...looks like the ones sold on ebay...but I cannot find a wiring guide anywhere?
Went to bunker of doom and saw catalogs but no help there...
Any suggestions?
1:13.3
500/333/200/125/50
89k
The six tabs are most likely the primary.  Per page 7 of the 1959 Stancor catalog,
"Has a dual primary-when properly connected the 500 and 200 ohm sections are center tapped."
stancor and utc kind of the same,
wire the pri-connect 3 to 4 and use 1 and 6 as input,
sec needs a push pull circuit, connect G to the grid and G to the other grid,
CT - no connection needed, just let it float, unless you are building a 670,
here is a pdf stancor catlog
http://www.clarisonus.com/Archives/Trans/Stancor61.pdf
4352 listed as mic or line to grids-
pin-out page should be available also, more searching...
