Storing Transformers
MartyMart
Berlin for a while
Is there any harm caused by storing many Transformers in close proximity in a plastic box ?
Mixture of Audio / Mic / power and gtr amp traffo's .... will this cause mag - demag between them !!
THX,
Marty.
They aren't magnetized, if that's what you're worried about. All the talk about magnetic fields and such can confuse, but there's no remaining magnetization when not in use.
I can see the misconception though... Tape reels stacked up improperly for too long can bleed through to eachother. The difference being that tape reels store energy, whereas transformers only transfer energy between windings.
Some transformers are too big to fit in your drawers:
"286-ton electrical transformer ...15 feet tall, 13 feet wide and 38 feet long"
http://bangordailynews.com/2012/05/19/news/lewiston-auburn/285-ton-central-maine-power-transformer-to-be-moved-along-highway/
They are moving another one today but it hasn't made the paper yet.
Made the paper (finally).
286-ton transformer draws stares on long, slow journey to Windsor
Several pictures, including the back-deck driver napping, and a horse. The video is good except there is 15 seconds of annoying ad before it; mute your speakers.
Note the road-slab under the truck. Maine has lots of 40-ton trucks: logs, heating fuel, beer. And this trailer seems to have 128 tires (16 axles, and there seem to be 2+2+2+2 tires per axle). And the trailer seems to have hydraulics to spread the load over "all" axles. Still they didn't want 286 tons going over bridges (that's a creek behind the guardrail) without a spreader.
Hacksaw? It probably all un-bolts.
PRR ( our member from Maine... ) So kind of audio system are you putting up at the substation?
> So what kind of core is that? 2 E cores?
Any large power is handled as 3-phase. Saves line copper.
3-phase can be done on three cores, or 2 cores, but there is economy in using one core.
Wound strips are popular in smaller sizes (shorter than a man):
In the big stuff, the corners of the core are rounded for less copper per turn (area/perimeter of a circle versus a square):
Did they mention what MVA it is?
that is the empty weight,
when it gets to the site, they roll in fuel trucks to fill it with oil,
if you tried to ship it with oil it would pop those tires,
those tie down chains are just to keep the cops off your back, they would pop like pop corn if the driver took a corner too fast,
they should have transformer races at Talladega,  :D
i wonder who did the crowbar test, they energize those things then crowbar them (short them out with a big shorting stick) at the peak of the sine wave, this puts a huge amount of DC on the coils,
F=1.257 NI, so maybe 5,000 turns and lets see, 1000 amps per sq inch, so if they use multiple sections on one coil of #4 rect, (rectangular wire), then we are talkin 6,280,000 Gilberts which is enough torque to spin the coil on the core which will snap the leads like a dry twig in a stiff desert wind,
rectangular wire can be torqued down on top of each other with great force, like stacking bricks, but if you nick the enamel from mis-handling, or a factory defect, and squish the wires together, you can get a shorted turn, which will heat up red hot like a branding iron in about 2 micro seconds, that is when the trouble starts, so there is huge stress on the winders to watch the wire as it rolls on, they have their name on every coil so it gets traced back to the guy who wound the wire too close and rubbed off the enamel, which caused the explosion and subsequent oil fire,
those are circular coils so you lay down different sized lams to form a circular core on a big steel rack, then you bolt on huge core brackets that look like i beams and flip the core up, then you lower the coils on with a big hoist,
our foreman was showing the president what a good job they did filling the tank with oil and while he was bending over the tank, a steel ball point pin fell out of his shirt pocket and lodged inside one of the coils, the coils have space between the windings for the oil to circulate and the pen happened to land just right, which means we had to drain the transformer, un hook the leads, hire the crane to come back and pull
the transformer to get the pin out,
i wonder what the core loss is on that thing, probably enuff to run about 5 houses,
is that thing for a Grateful Dead concert or something?
