RuudNL
A year ago I made a power supply for a tube condenser microphone.
I used a 'Chinese' voltage converter that can supply 6.3 V and a variable 150-280 V output.
Because I needed +120 V and I couldn't adjust the voltage lower than about 141 V, I added a series resistor and two zener diodes in series. (62V and 56V) As an extra precaution I added a 47 µF capacitor over the output.
This works perfectly, without any noise on the output of the microphone.
(Schematic is the top version in the attachment.)
Because of this success, I decided to create a second power supply for a U67, using the same DC converter module.
I wanted some extra filtering, so I added a series resistor of 4.7K and a 47 µF capacitor.
But... for some strange reason I can't get a higher output voltage than about 12 Volts!
Without the resistor and capacitor I can get 210 V. output, but as soon as I connect the RC combination, the voltage drops significantly. (Lower schematic)
When I load the output (without the capacitor) with two 10 K resistors in series, the output stays at 210 V. (So 210/20K = 10,5 mA)
Now, what would make the difference that the upper schematic works perfectly, but the lower schematic doesn't?
Just curious!
Just curious!
