user 37518
l
Dualflip said:I want to use a ballancer after the EQ which converts from -10dbu unbal. to +4dbu...
Dualflip said:Ohhh yeah i forgot to mention that, the fader is before the eq!, thats another reason why i want to keep the fader at 0 db, how ever i plan to take the output after the eq
Dualflip said:1954U1 said:A quick reply:
do you know that on your 169 input module you can re-arrange the path of your signal via the jumpers on the board?
[I mean, insert before eq or fader, after eq or fader, fader before eq, after eq.. all of that is documented in the official service-manual and in the addons.
if you want I can extract the significant pages and link them here]
Yes i have the manual, and yes i've checked the mods, as long as i can tell you can put the fader before or after the filter, but theres not any documentation explaining about placing the fader after the eq
Dualflip said:inputoutput said:I wouldn't change the 301s here.......: The strips sounds great, have great specs and a characteristic sound - with the 301! swap all the caps first and clean the circuit by cutting out all the parts you don't need.
Which parts did you cleared out?, i already recapped it with panasonic fm, need to change the tantals thou.
Dualflip said:Will do, thanks for the info man, btw as i said i posted a thread about the LM301 not long ago, you might remember it since you gave some very good tips, anyway for the other studer users here it is :
http://www.groupdiy.com/index.php?topic=35113.msg430113#msg430113
guy_4 said:These are not Neutrik transformers.
guy_4 said:On my 169 manual, page 4 of 5 of Input Unit schematic 1.169, dated 9.8.76, I can read :
Pos No : T1 Part No 1.022.405.00 Value 1:1 Specification : LINE-TRAFO MFR : ST
Pos No : T2 Part No 1.022.400.00 Value 1:4 Specification : MICRO-TRAFO MFR : ST
and just below : ST = STUDER
guy_4 said:From what components list do you get this information ?
