zamproject
- Joined
- May 11, 2010
- Messages
- 1,597
hello
I'm planing in the next few month to refurb/rebuild a large 5 frame Studer 289
I have questions and need advise regarding this
I actually run a smaller 4 frame 289 with 6 mono, 9 stereo input, 6 aux send/2st return and 4 bus/master, fully restored 3 years ago
I'm so happy with it regarding sound but quite limited with all stereo modules and total input (28)
The 5 frame desk have 18 mono with quadriphonic panpot, 6 aux send / 4ST return and 4 buss/master and need works to be on the top
My ides is to make a big configuration with both desk using the 5 frame desk (It's also possible to make a 6 frame but i don't want to definitely part one chassis)
target specification are:
-16 mono
-8 stereo
(32 input in total using 3 frame space)
-6 aux send with 4 stereo return
this will end in a 40 channel desk
-adding 8 stereo line out card for 16 patchable direct out trough insert
-For the bus/master i have to see what will be the best configuration
as i have 4 stereo compressor to load, 1 stereo filter and also the monitoring section (1 frame in total i think)
option is keeping the actual 4bus/master routing,
change to 6 bus/master (I can modify the ST sub group originally re-routed trough input as a bus/master)
or 6 bus + master (this could be done by chaining master modules, X input to 6 bus to 2 master)
So!!!
First, the PSU i think i have to add a bigger one or use 2 PSU to drive all this (5 frame full loaded..)
It's easy to calculate the total consumption as manual give all single modules needed current.
But i have no idea on how i have to calculate margin regarding PSU max output current.0%, 10%, 50% ???
Second, the summing
When looking at Studer history the 289 seem to be one of the first 32 input desk (for the biggest configuration), assuming 32 channels summing amp capability (with "less than 2 Ohm" input trafo on the bus/master unit)
What will append with 8 or 10 more input (saying 40total) loaded to the master bus?
Or are the limitation due to noise floor?
service manual say about noise
summing unit:
source 175Ohm (equivalent 18 input units)
bandwidth 20kHz
<6dB
input unit:
Noise voltage referred to the input
of the unit with a source impedance
RS=200 Ohm NF < or = 4,5dB (equivalent to -124,5dB at input, measured RMS 30-20k)
do you think i can do a noise simulation (for 40 input) with my actual desk by recording 2 time 20 opened input routed to the master an sum it in my DAW?
All suggestions and comment are welcome!!!
Zam
-16 mono
-8 stereo
So!!!
Second, the summing
summing unit:
bandwidth 20kHz
<6dB
input unit:
Zam
