Bo Deadly
Maybe check the wall socket to make sure neutral and earth are not accidentally reversed. Not sure if that would explain the problem but it couldn't be good.
abbey road d enfer said:I think it's a very important clue. Surely, the mains witch of the console PSU does not alter the earth circuit, so any ground loop is unchanged by the position on or off of the switch.
It means that turning on the PSU switch introduces significant leakage into the console ground. I would check for a defective Y capacitor. Y capacitors are between Line and Earth and between Neutral and Earth.
squarewave said:Maybe check the wall socket to make sure neutral and earth are not accidentally reversed. Not sure if that would explain the problem but it couldn't be good.
plumsolly said:According to the schematic, there are no Y capacitors in my console PS,
scott2000 said:surge suppressors may have some as well....
radardoug said:Is your power transformer putting out enough volts to allow for the drop across the regulators that they need?
This would be a classic problem, and as the mains varies, the regulators stop regulating. You haven't given a value for your picture, but the output from a 3 terminal regulator should be a straight line.
Have you checked with an oscilloscope?plumsolly said:Related power supply question: I have 18V secondaries and indeed, I measure ~18V RMS across them, so my DC should be about 18√2 - 2(0.7) = ~24VDC, but I am seeing more like 22VDC. What causes that?
I have not - but that makes sense - so the rectified dc voltage will depend on how close your mains power is to an ideal sine wave?abbey road d enfer said:Have you checked with an oscilloscope?
The √2 factor is correct only for clean sinewaves. In contrast, square waves have identical peak and rms value. The voltage from the rectifiers is always in-between sine and square.
The mains power is usually clean enough, but the interaction of various transformer losses and rectification seriously distort the secondary voltage.plumsolly said:I have not - but that makes sense - so the rectified dc voltage will depend on how close your mains power is to an ideal sine wave?
abbey road d enfer said:The mains power is usually clean enough, but the interaction of various transformer losses and rectification seriously distort the secondary voltage.
radardoug said:Paul, one thing to watch is if you are connecting shielded cable directly to the output of an opamp, the cable capacitance can cause the opamp to oscillate. This can be cured with a 100 to 200 ohm resistor directly on the output of the opamp to isolate the cable capacitance.
