thermionic
- Joined
- Jun 3, 2004
- Messages
- 1,671
Ilya said:Ok, I've found several candidates so far. Here they are:
1. B&K PRECISION - BK2530B - OSCILLOSCOPE, DIGITAL, 2X25MHZ, 500MS/S507
I like that it's B&K, but it's only 25MHz and 500MS. Min. sensitivity is 2mV
2. GW INSTEK - GDS-2062 - OSCILLOSCOPE, DSO, 2 CHANNEL, 60MHZ
I've no idea how good the insteks are. But this one is 60MHz. Min. sensitivity is 2mV
3. TEKTRONIX - TDS1002C-EDU - OSCILLOSCOPE, 60MHZ, 2 CH, 1GS/S
Rather expensive, and looks like an introductory model. Min. sensitivity is 2mV
4. TEKTRONIX - TDS2001C - OSCILLOSCOPE, 50MHZ, 2-CH
Another Tek. It's actually cheaper than 1002. Min. sensitivity is 2mV
5. TENMA - 72-8710 - DSO 100MHZ 2CH, 178MM (7 IN) SCREEN
Not sure if TENMA is any good. But this one is 100MHz. Min. sensitivity is 1mV.
I'm a bit lost right now. All scopes look good, but which one is better?... Any thoughts?
For what it's worth, if I only had one scope it'd probably be a green-screen analogue. Tek, Hameg and Kenwood are all good candidates for secondhand. Be careful with some of the more affordable digital scopes, in that the screen refresh rate can be quite slow... This can make it difficult to get a clear picture of some waveforms. Entry-level digi scopes can also be noisier than a good analogue scope for similar money - so signals below 5mV can morph into fuzz. I have two scopes: a digital Tek TDS2014 and a Kenwood 20MHz 4025 'beginner's scope'. If I really had to lose one it'd probably be the Tek... It gets more use than the Kenwood (the measurement functions are really useful) because I have an external analyser; but if I were relying on one scope for everything I'd have to go with the Kenwood because it gives me a clean image of signals below 1mV - the same cannot be said of the much more expensive Tek...
I sold the spare Hameg I had to a forum member. It was a nice scope. I really like Hameg gear. Is all the gear still built in Germany? Any Hameg built in Germany around the '80s / '90s will be reliable if treated well.
Justin
