The idea in loopback is to evaluate the frequency response of the combined ADC and DAC.I have a doubt about it,
Isn’t it possible than when doing that loop that the output circuitry of the soundcard (DAC and analog section) already limits the frequency response and that the input measures a lower kHz limite because the output can’t deliver that.
just to be sure shouldn’t the first tests of the input stage done with an external signal generator already known to be able to deliver the full sweep?
thanks
The idea in loopback is to evaluate the frequency response of teh combined ADC and DAC.
Actually, the frequency response of both is usually determined by digital filters that are very abrupt (very high slope) and essentially similar.
Indeed you could measure them separately, but it requires test equipment that you may not have at hand.
The QA402 has already been discussed somewhere in this group. Some swear by it, others not so much.
Absolutely, I would be lost without my old Ferrograph test set which goes right up to 150KHz.Of course, second-hand lab gear is an excellent solution.
I still use my old (1970's) LEA generator and THD meter, with a Hameg. It takes about half the space of my dining table, though, which is not small.
Indeed. Just beware that you may have response above 96kHz because of aliasing.I have a signal generator that is able to do sweeps and goes quite high in frequency, I can try with that
I believe Ian has one; he could chime on it...I'd have to go dig through Scarlett test reports to see if anyone has tested that in a similar way, as the Focusrite range would have to be the most common modern USB device that is relatively cheap and often available 2nd hand in its various revisions (and would be my goto if I came across a really cheap one).
I wonder how the TI EV board would work in conjunction with a DAC such as this oneTTLV320ADC6140 quad-channel 768-kHz Burr-Brown™ audio ADC evaluation module is also an option , it comes with an xmos usb controler card , every parameter is controlable in a very comprehensive software called pure path console...
...Im very tempted to try one of the E1DE Gen3 DAC's and use it as source for test signals, with the calibration available on the chip itself via the app it should be able to offer up an extremely accurate low distortion test signal to well beyond 100khz.
Neither had I.I hadnt heard of Flexasio before .
Damn!I have tried Asio4all but I couldnt get it to work in 24/32 bit modes .
So I'll try it first.Flexasio does appear to allow 24/32 bit .
Sure, when I can put my hand on the damn USB hub.Let us know how it works out .
I know what you mean. Every time I have to add another little bit to the DIY test setup the less I like it.Sure, when I can put my hand on the damn USB hub.
How would the software fare with two different drivers, one for the ADC, the other for the DAC?
Does anybody know?
The Scarlett will only go to 44K using the Java drivers when running on Win 10. So I just downloaded the Gen 2 ASIO drivers for it. Set the sample rate to 192K and ran a loop back test. The response is 3dB down at 60KHz.I believe Ian has one; he could chime on it...
That's one thing a Mac does native, but Windows must use a BandAid.I don’t know how it works in windows, but on a MAC that’s really easy to do. It recognizes both soundcards and you can make an “aggregate device” with the 2.
Then on REW you just choose the “aggregate device” as your driver, it takes care of the Clock Sync between both units also.
maybe there’s something similar for Windows
Thanks Ian. So, not too different than several others.The Scarlett will only go to 44K using the Java drivers when running on Win 10. So I just downloaded the Gen 2 ASIO drivers for it. Set the sample rate to 192K and ran a loop back test. The response is 3dB down at 60KHz.
That's interesting. Many people suggest using a USB powered interface in order to avoid potential issues like groundloop and extra noise.https://www.lifewire.com/best-usb-hubs-4142295
With a USB 3 hub it should be less of a bottleneck and should be easily capable of handling two audio interfaces . The ones with an external power supply might be better than using the laptop supply which is often a source of extra noise in audio interfaces .
