I had a quick look for bandwidth results operating at 192ks, and an ASR test showed a -3dB at about 65kHz for the 2i2. ASR also showed the Motu M4 was within 3dB out at 96kHz. I assume those tests were loopback, as it wasn't quite clear.
Most of the better interfaces use an internal SMPS to up the USB supply to something like 12V or so for better headroom and at the same time take the opportunity to add a low noise linear regulator so the quality of the mobo supply is much less of an issue. There are plenty of YouTube tear-downs you can look at which are most instructive.I guess it varies alot depending on hardware and what filters ,regulation and dc-dc conversion is involved , but in general Id favour an audio interface on its own dedicated supply anyday , thats not to say RF mush cant get superimposed on the audio path via ground either . Be interesting to take a standard USB powered interface and check how the noise figures stack up from a really quiet 5 volts vs hashy 5v mobo supplies .
It's a common issue, but very often the problem is not the soundcard in itself, it's the unbalanced connections that make the rest of the equipment share a common ground with the computer.That's interesting. Many people suggest using a USB powered interface in order to avoid potential issues like groundloop and extra noise.
Thank you for letting us know.Theres a new player in the audio test software game , seems like a usefull tool in that its dedicated to multitone distortion measurment , its only available in beta for now as some of the bugs are ironed out .
I had somewhat lost contact with ASR, to my loss. I see this long thread covers many of the caveats with Cosmos. Much more valuable than the Discord channel.More here over in the audioscence review Cosmos ADC page recently ,
They just warn about the dangers of damaging speakers/headphones/ears. I wonder if there's also some kind of limitation.Not intended for speaker measurements by the way.
