Suggestions on a small mixer PSU
KasperNyhus
Denmark
Hi all you clever people
I know similar topics might have been discussed earlier, and I have learned a lot by reading through them but I still need some advise regarding my specific project
So I building an 8ch sidecar'ish mixer with basically 8 312style pres with a NE5534 for HPF, a fader section with another 2520 DOA, a 12 slot 51x rack and some summing with 5532 and 2520.
My current math looks like this: (the numbers should be with a safe max current draw situation)
from a +16v regulated supply
Pre      8x 80mA    =  640mA
Fader    8X80mA    =  640mA
Sum    4x80mA    =  320mA
500      12x110mA = 1.320mA
Total 2.920mA pr supply side (+ and -)
I have measured the pre to draw about 50mA at max gain setting, the other numbers are guesses
My first thought was to make a 4 rail +-16v supply with LM317/337 and divide the current draw to the "pre/fader" and "sum/500", but that might be a little tight with only 1.5A max?
Then I thought about making a 3A supply with the LM350 as in the GDIY51x PSU but then I would need 4 sec windings on the trafo to make 4 rails, right? or two seperate trafos (takes up a lot of space...)
My next thought was to apply a booster power transistor to the 4 rail LM317/337 circuit
But I'm kind of lost what to choose here
I'm also building a +-24v supply for the 12ch 51x rack, a 48v supply and a 5v something supply for about 80 push switch LEDs, all to be fitted in the same 2U PSU rack case.
I want the PSU to be beefy and stable enough that I dont have to ever worry about it, and since its a complete DIY project some possibility of expanding with  extra channels in the future would be nice too.
Let me know if any of you have some comments or suggestions on what to choose
Thanks!  :D
