Sunday Night Gear porn (Demeter VTCL A, westlake Passive DI
pucho812
third stone from the sun
After a long day at an outdoor festival watching my buddies play in downtown LA, I came home and was ready to do more gear porn. Unfortunately my camera's batteries were starting to die so I got what I could.
We start off with a Demeter Tube compressor. It's got tubes and some IC's including the same IC for LED control as found in the solo 610.
Here we start off with the back which aside from 1/4,XLR, and TT jacks, it has a pin 2 pin 3 hot switch.
PSU
Amp section and control section which has IC's
and the front
We move into the westlake passive DI. A DI that has a built in roll off. The roll of can be assigned to the output of the DI going to tape or the output going to the amp. Third switch is for a ground lift. These were built with Jensen transformers.
The jensen transformer
The top shot of the PCB.
The bottom of the PCB with traces
The front
