olafmatt
[quote author="lagoausente"]A question about "low ESR". Is important the get all electrolytics low ESR or only the specified in the part list?
At the end notes tells: "electrolytic cap must have temp rating 105 and low ESR...[/quote]
Oh come on.... if you have the money get the most esoteric electrolytics you can find. But you won't burn your house when they are not rated at 105° (maybe you will, but that's not due to the caps then) and you probably won't hear a difference with high-ESR (no, you won't find those in the advertisement) types. At least the stuff I wrote in my PDF (supergreen_instructions.pdf) was meant as a general guideline, no need to follow it. Choose whatever cap fit's through the holes on the board. And if you don't like what you hear, get out the soldering iron once more and put in another type until you hear what you like. YOU CAN'T BUILD THE BEST SUPERGREEN BECAUSE THERE IS NO "THE BEST SUPERGREEN"!
Olaf
Olaf
