Hi All,
the Superlux S502 MK2 has arrived
Here are my first impressions and measurement results.
Subjective sound impressions:
It seems that the capsules are very well matched. With a small UKW radio 1m located exactly in front i am not able to find an audible interchannel difference when i exchange L/R channels.
In comparison with MBHO-capsules i would describe the sound as reluctant (very flat response, no hyped heights).
The noise floor is audible but not unpleasant.
I don't think that the stated sensivity of -36dBV is correct. I would say it is 2dB lower. More about that after exact measurements.
First measurements:
Both capsules have nearly the same polarisation voltage (60,2V and 59,9V).
Nearly the same capsule capacitance: 39pF and 40pF.
Wonderful: both backplate and membrane are seperated from case. This is important to use the real Schoeps circuit. More about that later on.
The mic self noise is moderately low: -116,0dBV(A) and -116,2dBV(A), see attached picture.
BUT: At 20kHz the noise level is too high. Such a high level i only know from OPA Alice circuit designs..
More measurement results will follow...
BR MicUlli
