Hi folks,
most of the measurement stuff has been done, here some results.
The first pic shows the frequency response on axis and under angles up to 180° for left and right channel. My estimation that the mic is not as loud as indicated in the datasheet is true. Sensivity is around -38,6 dBV (11,7 mV/Pa). The rear sound rejection is really remarkable good. Under 45° sound incidence the response goes up to 16 kHz without degradation. This is important for ORTF settings. For sound up to 90° incidence angle we see a 3 dB enhancement, the mic sounds "fresh" without harshness. The highpass 3 dB corner is 70 Hz (free field conditions), very well done for an SDC capsule. Another highpass corner is at 25 Hz because of the Schoeps circuit. The capsule matching is tight enough.
After adding some modifications to the electronic part some enhancements could be measured as the second pic shows. The A weighted noise levels are -116,1 dB and -117,0 dB (modified). Note the improvement at higher frequencies. The self noise could be reduced from 16,5 dBA to 15,6 dBA, perhaps not worth doing a mod
The max output level of the circuit is +1 dBV for 0,5% THD. This translates to a max. SPL of 133,4 dB, very tight to the datasheet.
The 3rd pic shows a weakness of the circuit. There are a lot of noise components above the audio band. This holds also true if only one oscillator is at work, nevertheless one oscillator must be put to death because you never know where the beat frequencies occor. The noise is gone when both oscillators are disconnected. This problem could not be solved whatever i tried. Must be the messy board layout..
I also have tried the mic capsule with my MBC5X0 board with very good results. Because of the smaller pol voltage (39 V vs 60 V) the sensitivity is 3 dB smaller, but also the electronic noise. Therefore the self noise stays at 15,6 dBA and fortunately the max. SPL goes up to 140 dB
. NO MESSY noise components above the audio range. Probably i will design a board with 2x MBC5X0 circuits that can be used as a replacement, stay tuned..
If you want to improve your S502MKII i recommend the following steps:
1. MANDATORY. Put one oscillator to death by removing L2 or L2a. Connect both channels together for pol voltage with a wire between cathodes of D1 and D1a and for oscillator supply with a wire between plus of C5 and C5a. This ensures that the mic works with only one cable (L or R) connected.
2. RECOMMENDED. Desolder T1 and T1a, replace them with 2 low noise JFETs like 2SK209BL or NSVJ3910 (my favorite). Desolder T2, T2a, T3 and T3a, replace them with BC807-25 or FMMT591 (my favorite). This gives the pretty low noise floor at higher frequencies.
3. PLAYGROUND. Desolder R1 and R1a, replace them with BAV199 INF double diode (connected antiparallel). Add 2 MKT caps 0,15u/50V between wiper of R2 (R2a) and source of T1 (T1a). This lowers the noise floor at low frequencies.
After modding the circuit adjust R2 and R2a for a voltage of 1,6 V across R3 and R3a. This is a compromise between headroom and low THD at smaller levels.
My verdict: Superlux S502MKII is a very fine mic, cheap enough and a must have for all mic freaks
