Here is the preamp, all the controls are dual pots, there are some cut traces and jumper wires so it looks like it was in between revs,
clever cathode cap scheme, as the volume is turned up, the first stage cathode cap starts to boost low end by getting it's ground leg closer to ground,
bass pot looks like it would work backwards, we will see when we fire it up,
the second cathode cap can be switched in or out by way of a foot switch for more gain,
will get some voltage readings after reassembly,
