plumsolly
Cool. A few more questions before I power it up. For the output, its balanced and I just attach ground to the C.T. terminal? For the input, there are only two terminals, but there is a ground connection and C.T. connection on the input strapping terminal board. From the manual: “The center tap of the input transformer is brought out to the terminal marked C.T. The terminal marked G is connected to the chassis of the amplifier. If the input line is balanced to ground, it may be desirable to join these two terminals.” So, should I join ‘C.T.’ and ‘G’ and also connect the input ground to ‘G’? Also, can/should I attach ac safety ground to ‘G’? As for testing for DC, I just have my meter set to read dc and check the junctions of C6/R13 and C7/T4 against case ground? What is an unreasonable amount of DC?
Thanks a ton, I wont have been able to have done it without you. Best, Ben
