plumsolly said:
The frequency response in bypass literally goes from something like -50db @ 20hz to 0db @ 20k in a straight, diagonal line. It looks like this '/'
plumsolly said:
It seems to work properly as an amp now. Can't tell you exactly how that happened... wire jiggling and such.
So I have been having this problem intermittently while I have been restoring it. I figured I would eventually trace it to a bad switch contact, cold solder joint, loose tube socket contact, etc... I finally did trace it ... to a sketchy secondary on T1. Sometimes it's good, sometimes it's open, and (less frequently) it's in between. I took the transformer out and I can't consistently get it to be good or open; jiggling the leads (usually) doesn't make a difference, it doesn't seem temperature dependent (I thought maybe the slight expansion/contraction of the potting compound could be making it make/break contact), it just works sometimes and sometimes it doesn't... I'm wondering if the problem might be right where the lead meets the coil and whether it couldn't be solved by melting the potting compound and reconnecting the lead without having to unwind the coil.
Best, Ben
