gswan
Nothing wrong with using a suitably designed switcher in it, provided you know what you are doing.
gswan said:Nothing wrong with using a suitably designed switcher in it, provided you know what you are doing.
Rob Flinn said:I was just talking with a friend who said he thought that maybe the electrolytic caps on the output should be paralleled with some small ceramics. The reason being that any HF parasitics could cause a large current draw that causes the supply to start shutting down, when it shuts down enough the HF parasitics stop, & the power supply switches on again & the whole cycle repeats causing the motor boating.
What is your definition of large cap ? (+sum of rail bypassing caps per channel)..generic switch mode PSU modules, each of which had an additional large cap strappped across its o/p..
Rob Flinn said:The 24v supply which is for relays is 8.5A out so it's rather alarming that the relays are chattering. I'm basing this on my MCI which has a hell of a lot more 24v relays & only has a 3A linear supply for them.
Rob Flinn said:On further investigation this does still appear to be a load dependant problem. This is because all the channels I had marked as bad apart from 1 worked when other channels were removed. Also sometimes when I switch on the psus motor boats, but if I switch it off and on quickly it stabilized.
