Using switcher mofules with inbuilt power factor correction adds another level of (different) noises to the DC output as modules
Yes. A modern agency compliant SMPS built to "commodity grade" standards makes quite an interesting wideband noise generator.
I use LC filtering then a LOW dropout Linear regulator ( half a volt at however many amps are needed) to clean up the resultant DC AND offer remote sensing in the 'linear' domain (at the expense of a little bit more wasted heat).
My personal take, commercially, is to use a high current Stepdown (Buck) converter to make a new "lowest common denominator" rail.
Say I want to handle 12V to 24V DC input, use a 100% duty cycle Stepdown with 36V withstanding voltage Step-down to 9V. Common IC's I employ are 5-8A output, over 800kHz switching frequency and can be synchronised externally, so two or four can be used in quadrature for higher current.
In an extreme case we might make a local PCB power bus using multiple pcb layers that operates effectively at 2.8MHz switching (4 pcs interleaved chips) with 20A @ 9V with a pretty much universal input DC for vehicular or other applications.
Now that's 180VA of DC. And what follows can be > 90% efficient, input power maybe 220VA from DC.
Then use externally synchronised boost or buck converters (> 1MHz switching) to make the actual voltages needed.
Modern switchers use bandgap references, so audio band noise is comparable to any linear regulators using unfiltered bandgap references.
Switching frequency, once you run at ~1MHz all components needed are tiny SMD. So while complex, such a system contains all noise on a "noisy island" and physical size can be very small, compared to power levels.
Example of such a design. The Mezzanine PCB to the left filters incoming DC (two inductors on top of PCB) and prevents conducted EMI.
Next a tiny drunk (legless) Buck IC makes 6V/6A (to heat tubes AND power the rest) and using a dual winding inductor makes an extra galvanically isolated ~6V/2A supply (logic, usb etc.).
A total of eight different supplies (including dual +/-18V supplies that are tracking negative and CPU adjustable positive via PWM) are then generated. Two of them use a greinacher cascade to make tube HT.
The big advantage of this approach is that after the buck converter we control everything, we can syncronise our switchers to any suitable clock, phase locked. We ignore the incoming DC totally and what noise we create locally we deal with locally.
The "Brick" vendor worries about agency compliance and power, we don't give a pair of fetid dingo kidneys how noisy his product is.
A replacement supply MUST give overall performance as quiet as an original properly functioning supply so in general terms less than say 5millivolts measured DC to 500KHz
Ahhhm, microvolt, not millivolt!
Otherwise 100% agreed.
Thor
