TAC Magnum - 3 Way Meter Switch
Siegfried Meier
Ontario, Canada
Hey all!
I'd like to modify our console's meter bridge to have 3 states (currently and stock, the meters only read buss out levels). But, I'd like the meter to also read line in and tape in if possible. I'm unsure exactly what sort of a mini toggle switch I'd need for this (and it has to be tiny, as there isn't much room on the channel)...but basically something with 3 inputs and 1 output. Any thoughts?
Sig
You can get 'on:On:On' toggle switches. Not looked for them for ages and I am less sure the 'micro' size toggles have them in their 'range'. There are other ways of adding the function. A miniature changeover relay might be good if you wanted to switch 'all' meters from say line in and tape in. Or even more intersting in blocks of 8 channels 9or any other combination.
