Hi, I can't seem to find confirmation on this, but from what I found, there are two versions for the Tascam DB25 pinout. Audio cables version(8 ins or 8 outs) and the AES/EBU version(4 in and 4 outs).
Yamaha seems to only have one version which is the AES version which is 4ins and 4outs, with the grounding part that does not make sense to me.
I noticed units like the Lynx Aurora uses Yamaha pinout for their DB25 connectors for both the Analogue and AES/EBU DB25 ports. Does that mean that both ports use the Yamaha AES version wiring unlike the Tascam. Is there a standard though for which pins of the Yamaha AES pinouts would be used for each channel in an 8 channel ins/outs cable?
Thank you.
Thank you.
