Kir_For_Pleasure
thanks !
pacemaker said:Hi John,
thanks for the info,
i just got an answer from tascam about the power transformer :
"The only info we have is what's in the OM/SM,(which you probably have)."
great answer ! ;-)
John, please can you tell me, regarding the 6.3A fuses,
wich are between the diode bridges and each Tx 18VAC secondaries
Am i right to presume that fuse value have to be a few more than the needed current for the console
and a little less than the available current of the transformer ?
If i'm right,
This TEAC 5320058500 transformer might have 3X18V output at 8 or 10A ?
Right ?
pacemaker said:the +15v is 15,80v
and the -15 is -14,90v
I would like to adjust them for the perfect voltage,
and would like to learn too,
the different PSU i built, Mnats, peterC and others available here,
had resistor to ground adjusting the voltagen
On the 3500 schematics, i wasn't sure wich ones settle the voltage,
I'm hesitating between two,
With the answer, i will be able to learn and understand this circuit ,
Regards,
Francois
