Anybody tried this? Does it have a proper transformer like the Alctron one?
https://www.thomann.de/de/the_tbone_psu_retro_tube_ii.htm
RuudNL said:I have one. It is not bad. I changed the zeners, because I needed 105 V for my microphone.
Also the 6.3V was as bit on the high side. (6.7 V)
It has a standard (E-I) transformer.
They use a 7806 regulator, but the output is 'lifted' 0.7 V by using a diode in the ground leg of the 7806.
I simply added a 1 ohm resistor in series with the filament voltage, this brought the voltage at the end of the cable to 6.3 V.
The power supply looks good, although it would have even been better if there wasn't 'TBone' printed on it...
TLRT said:Thanks, I was curious if it has at least a good quality mains transfomer like the alctron - I have my own CNC'ed PSU house, but sometimes I need something cheap for a project,etc...
RuudNL said:The transformer is completely silent in my power supply.
