That looks like an "OrCAD" schematic from 1996!!! If you happen to have access to that OrCAD schematic CAD-file, I could import that into my current CADENCE/OrCAD "PCB Editor" program and then I could spruce it up a bit!!!Is the fuse still in one piece? What about diodes (both the bridge rectifier and others found on the primary side), and the main switching MOSFET?
Just sayin'.....
"Live & Learn".....huh???@Khron On my way out to Burbank now.
I should’ve just grabbed one yesterday.
It turns out that the YouTube video about the power supply repair that I watched was directly derived from this thread.
That’s the one where the guy had also swapped out C5.
I wouldn’t even know where to look for that. So far, the only things that I have been attempting are suggestions that have extreme clarity within their instructions.How about the upc/uuc (variations) pwm chip on the riser board !![]()
If I may interject again.I wouldn’t even know where to look for that. So far, the only things that I have been attempting are suggestions that have extreme clarity within their instructions.
My level of expertise is so low that my DIY experience has been building direct boxes & transformer color boxes, and specifically NOT troubleshooting dead power supplies - in other words, I barely know what I’m doing and this is beginning to feel a wee bit out of my jurisdiction.
Obviously, the C5 replacement was ineffective.
I am sure I don’t have the time or the patience to replace every single component one at a time And that may not even necessarily solve my problem.
I suspect that this particular project may be better left in the hands of someone who actually knows what they’re doing. If I continue, it’s going to end up back in a box in my garage which is where it has been for the last 15 years.
C5 replacement didn’t work, either.It won't hurt to refresh that one too.
Thanks.If I may interject again.
As you live in Los Angeles, when it comes to digital gear I highly recommend ADS. Audio design and service is in burbank. Talk with norick. I think that is how you spell his name. Anyway they are great. Back in the day, they used to sell me Alesis parts as they were an authorized repair center for them.
They are good people and are quick to fix items.
They are my goto on digital and overflow although I haven’t had overflow in a long while
I haven't been following along closely but what unit is it? and what seems to be the issue exactly?C5 replacement didn’t work, either.
I
Thanks.
I spoke to him on the phone yesterday.
He politely opted out.
I am secretly hoping someone in this group might be interested in taking this on.
TC Electronics Fireworx - circa mid 2000’sI haven't been following along closely but what unit is it? and what seems to be the issue exactly?
Can you confirm that the psu is indeed faulty? A unit not powering on while it points to a psu fault maybe be related to something else.TC Electronics Fireworx - circa mid 2000’s
Doesn’t power up anymore, so I had hoped that following some of the instructions in this thread would revive it, but in this case it needs a little bit more more TLC and far more than I probably know how to give.
Replacement power supplies are no longer available.
So far, I have replaced two capacitors at C5 and C7 and checked the fuse.
That certainly sounds like it’s way out of my jurisdiction.Can you confirm that the psu is indeed faulty? A unit not powering on while it points to a psu fault maybe be related to something else.
I understand. I can take a look but unlike analog gear I couldn't promise anythingThat certainly sounds like it’s way out of my jurisdiction.
Just to be clear, I am an extreme noob
We definitely got that covered based on the initial Svart posts, but it had no impact.2) You can't use just any cap with the same marked value. You MUST use a low ESR cap like Panasonic FM or FR series, or Nichicon equivalent (HE, I think).
Well, occasionally one of these supplies was just...dead. I may still have a few of these kicking around...I can check next week. If I revive one, I'll let you know.We definitely got that covered based on the initial Svart posts, but it had no impact.
(Panasonic Low ESR 105C)
