Telefunken TDA-1 DI transformer info needed
madreza
Paris, France
Hi guys. I need to replace a TDA-1 DI ´s transformer
I can’t find any info on that
Any help would be great 🙏
    68.9 KB
    121.6 KB
Somewhere along the OEP A187 line, it looks like you've torn out the pins pretty royally otherwise it'd have been pretty easy to match up the DCR on the windings. The box as a whole comes off as a pretty low effort product so if i were a betting man i'd be very sure it's just a relabeled off the shelf trafo and not a custom made one. If you can somehow measure the DCRs, do that and you'll have a very easy time finding a replacement.
This one is the only one i could find that matches the pin layout at least
https://carnhill.co.uk/wp-content/uploads/2019/07/A187A13C.pdf
You will have to give us a bit more info than that, for someone here to be able to help.
At least take out a Meter and mesure the Primary and Secondary Resistances and compare with existing OEP products like the ones sold on RS, second picture below.
https://fr.rs-online.com/web/p/transformateurs-audio/6676044
PS: just to clarify, I'm not saying this is the exact very same one as yours.Just a guide.
Bonne Chance.
M
    448.1 KB
    134.4 KB
You want a 1:10 ish ratio
PRI dcr around 30 ohms
Sec dcr about 3 k ohms if that is any help
Oh, and shields between PRI and sec and around the whole enchilada
